Hi Guy's,
Newbie here please bear with !!
Just bought my first 944 UK spec 2.5 1987myr 8 Valve with 113.000 M/s. in red.
Begun the nessesary maintenece and servicing (Replaced handbrake shoes and both cables (long one the ferrule was seized solid into the body had drill it carefully !!! all done works a treat now.
Am looking at doing the Timing Belts and water pump and would appreciate any thoughts on what to replace as a belt and braces job..no pun intended.. (i.e do i fit a turbo water pump ? do you do any furher work seals etc and the tensioning side ...tool etc etc etc .
I have access to full garage facilties... but not the tensioning tool !!! any tips thoughts would be much appreciated.
zola1
