Hello All
i just ordered the outter pillars for my cayenne in black
the front two remove no problem without a hitch
but the rears are a PITA :cursing:
I was told i need to remove the rear glass via Lorens pdf
anyone ever do this or have ideas if you must remove that rear glass?
thanks
Marco :clapping:
First of all you have to remove the interior trim, the glass and pillar have a fixation with nuts.
Success.
Success.
So such as the headliner? or how and what needs to be removed inside?
how much would the dealer charge to remove the 2 rear?
is it a big deal to remove the rear pillars i have doen minor work on the cayennes
Only the side trim must be removed, replacement rear pillars = approx. 2.00 h. of labour for a experienced person.
Dealer will ask at leas 2,5 hours for rem\reinstall rear glasws only.
Really you do not need remove all windows, C pillar trims fixed on double side tape on surface and two plastic clamps on front edge. From my practice I know no possible to install new part as strong as original one installed, we allways add some glue to adhesive tape.
If you have one glass removed to see inside - you can see how to carefully remove original part and glue new one with pu sealant witout any works on interior trims.
regards.
Alex
regards.
Alex
How do you mean? i was told need interior parts remove to install rear trim
i am thinkin remove seat belt cover (inside pillar) and then screws must be ther?
Hello! No, inner c pillar trim not enought (or not nessesary, do not remember). You should remove side trims of trunk and d pillars first.
Regards.
Edited by G_A
Regards.
So from the trunk remove the interior headliner? and then what pillars?
can you pm or email me?
  • 3 years later...
Cayenne 17,
Were you ever able to replace the C Piller covers without removing the window? I want to intall black ones. Any help would be GREATLY appreaciated.
Matt
