No. IIRC, when I did this on my 928 I put the left hand side into the slot on the right hand side and then used a pair of pliers to grasp the end while pulling/bending it back. Think it wraps around a slotted/ridged part of the rubber/joint so this helps keep it in position, a belt and braces sort of thing. Be more obvious when you have the other one out I think.
