My friend just had his rotors replaced. He used yellow race pads
and did a lot of track events. He had some cracks between holes.
He said you can chamfer the holes to reduce squeaking. Does anyone
have any other feed back on this?
Does anyone know what the mike settings are for new and for replacing
the rotors?
I am thinking of getting thicker pad greese to stop the squeaks. Once the
wheel is off, I will mike the rotors.
Paul
If you want rotor specs I will need model year and exact model...
Hi Loren,
The car is a 2006 997S coup. My car has
the big red brake calipers. I would almost assume
that the 996 rotors are the same.
Thank you again for providing this information.
Paul
I believe the brakes on the 2S are the same as the (mk2) 996 GT3 - so that would be:
Brake disc thickness, new
front 34mm
rear 28 mm
Brake discs minimum thickness
front PCCB = 33.5 mm
steel = 32.0 mm
rear PCCB = 27.5 mm
steel = 26.0 mm
Thickness tolerance of the brake discs, max.
0.02 mm
Lateral runout of the brake disc, max.
0.03 mm
Lateral runout of the wheel hub, max.
0.03 mm
Lateral runout of the brake disc when installed, max.
0.06 mm
997S brakes are the same as 996TT (not GT3). I don't have specifics... As to squeal, it's a result of high performance and I've never found any sort of anti-squeal goo to do anything other than mess things up.
Not according to my parts list...
The 997 TT rotors are different numbers from the 997 2S and 4S.
