  • 7 months later...
Anyone know how to install the non smoker's tray? Thanks in advance.
Here's how:
Remove the trim around the outside of the central stack. It is the bezel (black matte plastic in Cayenne and Cayenne S, matte silver on Cayenne Turbo). You pry from one end, it's just held in with clips.
Remove the climate controls-- these are held in with two metal spring clips, one per side. You have to use a small screwdriver to lever up and release the clips
Note to remove the climate controls, you will need the car in Drive or at least not in Park
Below this, you will find two torx screws holding in the ash tray. Remove these. The ash tray slides out. Behind is a connector to supply power to the ash tray, unhook this.
The non-smokers tray replaces the ash tray and goes in with the same two torx screws.
Push back in the environment controls until the clips snap in.
Replace the bezel.
Total time: maybe 30 minutes tops!
Non smokers dont need cigarette lighters, the answer is yes he's gone.
Non smokers with ipods and cell phones need them ;)
I have the new non smokers tray and have removed the bezel but am unable to find the 2 "clips" that I need to remove. If anyone could provide more detail or a pic it would be greatly appreciated.
Would be easy to modify that tray to include a 2 outlet 110V inverter....
Thanks for the idea - believe it or not I just found the 2 power outlets under the glove box that I have been looking for over the last 4 months!
I would like to put my ipod hookup from the MoBrodge in that tray if possible...
And again does anyone have a picture/diagram of what clips need to be removed in order to pull the climate control???
JR
I don't have the picture, but the clips are behind the little black holes on each side of the climate control. You have to use a small screwdriver and push in very hard.
