I've as 2000 Box, never wrecked. Rained like crazy here last weekend and for the first time ever I've got a small leak that's coming through just above the footpedals. Ideas?
TIA, Jef
I would start by clearing the front drains. They are located under the front hood. You have to remove the plastic panels next to the battery and blow out the drains (easy to do - one screw on each side). Stuff gets lodged in the drains and you have to periodically blow them out.
Mine was bad enough to drip when the a/c was on. When I had it in for brakes, my Tech cleared out the drain tube that sits right in front of the dash. Haven't had a problem with it since.
