If you look between the oil filler tube and the alternator, you can see his back end. Use a lamp he is on the other side of the engine.
Top of the engine, under the back crossover tube on the intake.
If you are planning to replace it (I had someone do it for me on my car), plan on a LONG time to do so since you have to remove many things. Its not the most comfortable thing to do on these cars.
