Hello all,
I am in the process of choosing the right components to update the audio system in my 2001 Porsche Boxster. So far, I have replaced the dash and the door speakers. When I replaced the dash speakers with Infiniti Kappa 42.7 i (specs below) I noticed a great improvement, however the replacement of the door speakers (with 5 1/4 focals 130 CA) did not benefit much the bass of my car. I further noticed that the dash speakers are 2 ohm while the doors are 4 ohm. Can that have any impact on the results I am getting now? Should I have replaced the door speakers with 2ohm’s coaxials based on the current amp I have HAES (4X40w non DSP). I don’t have the specs for it…
The other question I have is what amp should I chose (or what specs should I look) as I chose the replacement for my current HAES, based on the speakers I replaced (specs) below?
Thank you very much for your great support (I love this space)
Gustavo
DASH
Infinity Kappa 42.7i (4’’)
2-way 4" speakers (pair)
2-ohm impedance
Plus One woven-glass-fiber woofer cone with rubber surround
M.M.D. dome tweeter
computer-optimized outboard crossovers with tweeter level control
power range: 2-50 watts RMS (150 watts peak power)
frequency response: 75-25,000 Hz
sensitivity: 93 dB
top-mount depth: 1-13/16"
warranty: 3 years
DOORS
Focal 130 CA (5 ¼’’)
Frequency Response (Hz) 65 - 30,000 Hz
Impedance (Ohms) 4
Model 130CA
Peak Power (watts) 100
Recommended Power Range (watts RMS) 50
Sensitivity (dB) 91
Speaker Size (inches) 5.25
Speaker Type 2-Way
