-- Check control wire for A/C relay, pin 2 (terminal 85), for short circuit to ground.
1. Remove A/C relay.
2. Remove DME control module connector.
3. Connect ohmmeter to ground and pin 2
(terminal 85).
Display: infinite ohms
If 0 - 5 ohms is displayed, check wiring for chafing and
pinching damage.
I'm having difficulty with step 2, locating " DME control module connector" . It a rat's nest of wires, anyone know which connector block it's in? Or do I just trace back from terminal 85 and look for chaffing?
Thanks.
Edited by demonz
