I recently replaced my stock shifter with a Porsche SSK. Everything appeared to be fine. Just the other day someone told me that my reverse lights weren't coming on. I did a search on the renntech and checked the fuse as suggested, working fine. Another post mentioned replacing the reverse switch by the tranny. Before I do that I want to make sure I'm not overlooking anything else. Could there be something that I need to check with or around the shifter itself? Any advice is greatly appreciated. Thanks.
I had to replace mine a year ago in my 996. After buying a new one and relpacing it, I thought I would check out the old one to see why it failed. Using my meter I checked it and it was working fine. The plunger was just a little sticky so a few repeted pushes and a quick blast of lube made it perfectly operatable.
