I just bought this 1997 Boxster its in great shape but I cant see the OBC I can make out that it is working when toggling between functions if I get right down to it. Is there some way to turn the bnrightness up on this feature?
Is the brightness of the digital readout of the MPH dim just like the OBC or is the MPH brighter than the OBC display?
if not, the brightness adjustment is the knob between/above the RPM gauge and MPH gauge, twist and hold it to the left to brighten the display.
If that doesnt work, you likely have a burnt out light bulb in the gauge assembly. to replace that, look for directions on how to remove the cluster from the dash.
Edited by CJ_Boxster
No just the area where the settings for OBC are. Do you know if the LCD is backlit? Thanks for offering the help
