Hello:
Can anyone confirm the below part numbers for the Amplifier in a MY03 996 Coupe, CDR-23, with bose hi end and changer system (MOST) are:
996 645 333 05
996 645 333 04
Potentially on the hunt for this amp, and want to confirm the numbers.
Many Thanks, Ross
996.645.333.04 was replaced by 996.645.333.05 which was replaced by 996.645.333.07.
So, 996.645.333.07 is the latest version.
Thanks loren - are these "plug n play" or if i get an .05 or .07 will i need a PST2/PIWIS to recognize it?
If you are replacing a BOSE amp it will be plug n play.
If your car did not have an amp you will need the correct fiber optic (MOST) cable(s) and a PIWIS (or PST2) to turn on the feature.
