Went from the gym to the supermarket, car ok. When I came out and started the car it sounded like I'd got into a chavved up Nova with a 9" exhaust by mistake. Very loud. Any obvious places to look for a fracture or is there some other part of the system I should be looking at?
No engine check lights.
Edited by Paul Fraser
The bolts holding the short connector that covers the gap between the cat pipe and the silencer had broken (one has already fallen off). The short connecting sleeve had slid down the pipe leaving a gap.
Sorted temporarily with £2.40 worth of jubilee clips.
Quite a bit of corrosion under there, Best check the whole system, as well as your suspension components.
