What/where would be the easiest way to pull a 12v line to the center top of the dash? Don't like the big cigarette lighter thingee for my GPS.
-- peer
Nick...
..thank you very much -- it saved my day. That connector is exactly what I used, (its second hole is the hot, and the fourth one is ground). Here's how my GPS ended up after an assault with the Dremel tool on the shelf-department.
-- peer
Nick...
-- peer
Can you even see that screen while driving?
Yes, very much so. Of course, it would be even better if it was high up at the windscreen, but then I had to remove it (and its mounting) whenever I parked. To me it's a compromise.
-- peer
