Hey all,
I thought this would be easy to find, but im having no luck ;). I need to find the pin-out diagram for the haes 996 cab amplifier. I'm trying to install a rockford 3sixty and i need to know which wires are source wires. Any help would be GREATLY appreciated!!!
Justin
Loren, for giggles, when you get time can you help with the my 99 pinouts? I've done it the hard way but would love to have the diagram to double check my work.
MY99 amp pinouts
  • 5 months later...
  jurichar said:
AWESOME Loren....thank you very very very much!!
Hi Guys, I'm also trying to wire a new amp (audison) in place of the original HAES 4x40W (986.645.323.00). The diagrams posted seem to describe the 20-pin connector in detail but not the smaller 18-pin that is also on the amp. Any chance someone can post this detail? It would be GREATLY appreciated!!!!
I have a 2001 Boxster S.
Many thanks,
-randy
rboutin:
Notice that the diagram shows Plug I with 18 pins and Plug II with 20 pins. The black plug/connector (smaller) has 18 pins and the blue/natural/brown/green, depending if cabrio or coupe,etc. has 20 pins (bigger). The pinout and wire color codes are on the same big rectangular thas says "Amplifier 996". The top is for Plug I (small black) and the bottom is for Plug II the big one. Hope this helps.
  hi8ha said:
rboutin you have a PM.
Hi guys,
I am also think about replacing my HAES 4x40W (same as Randy)...Can anyone provide me with a diagram?
Thank you so much,
Gustavo
Edited by gandrade1
