Does anyone know how to remove the three dash trim pieces? (the ones that separate upper and lower dash) Is it easier just to drill, or break out the old parts? Thanks, Mark
The dash is one big piece. The 3 trim pieces are held in by about a dozen screws. The 'proper' way is to remove the dash, then the screws.
Some guy took a drill and drilled the heck out of the plastic trim and was able to get it out from the front of the dash. On Rennlist they say if you can pull on the trim then the screws will pull through the dash or pull out of the back of the trim, or something like that.
In this picture of a dash the trim has been removed. You can see the holes for the screws. Jeff
Jeff;
Thats a whole lot of screw holes!
Looks like Porsche used more screws on those three pieces than the entire balance of the interior combined.
Dang!
Doug
'02-C4S
I have also heard about the pull out the front technique. It is hinged on the fact that you pop out one side of the head at a time and that you take your time so that the hole is not masacred.
I tried to remove the stips yesterday with the pull technique and those things are in there! I wasn't able to make them budge!
SPR....what exactly did you try? I'm trying to get up courage to do it. I figure I'll ruin the OEM strips in the process???? :(
I tried prying them out with a screwdirver = flathead. And no luck I was pretty worried while doing it so I didn't go that far into it and I didn't want to risk damaging the surrounding dash, i.e. indentations etc.
