The gas pedal on my 2000 Boxster S is kind of sticky instead of smooth. I'm sure a little lube in the right place would fix the problem. Has anyone encountered this? If so, how do I remove the pedal or where should I lube?
Thanks.
This is probably not your pedal. Most likely you need to clean your Throttle Body. This is common on all vehicles where it gets gunked up. Typically it is determined by quality of fuel used, quality of air filter or frequency changed, climate, mileage, etc.
