I will be fitting a used hard top this week as well as installing the rear speaker shelf. I have been looking at the wind block glass and attachment parts for over an hour and do not see how the plexiglass disengages w/o breaking the cheap looking plastic attachment system.
Anyone got a trick or obvious item I'm missing here?
Thanks.
Shawn
When I fitted my hardtop and the rear parcel shelf I left mine in. However, to get the wind deflector out you need to unclip the black clips at the top on the deflector. Search on 'wind deflector' and you should get some instructions/photos on here, sure I've seen them
Thanks but those key words don't produce anything useful for my need.
push the windstop down (for sure) and forward (i think, maybe back though) while gently pushing the clips towards the middle.
Why would you need to? I imagine you could own those little plastic thingies that go inside the roll bar hoops for a couple years and never need to remove them.
See, this is important knowledge you don't get when you never go faster than 135mph. :D
Mine stayed on fine @ 140mph... :drive: :oops:
