Have a 2 button key. Just out of the blue, the buttons will not open or lock the door or the hood. The red light is flashing on the key when the button is pressed. Also too the battery out to check if the batter is good. 3V perfect. The door will lock from the inside by the button on the dash board. Any ideas on what may have or is causing this?
Thanks.
The remote stops working after approx. 5 days of inactivity, trey this: open the door with the key-push the key in the ignition switch-turn contact on, at the same time push on the button of the remote to recognise the system ( announcement )-pull the key out and trey to lock the door by the remote. If it doesnt work, there is a good change that the remote is faulty and most by replaced in a O.P.C. to programmed.
Yeah I gave it a try and didn't work. I guess it off the the dealer I go. Thanks for the help. <_<
