Patience is good here (as hfisch said). Expect 20 minutes or so per side.
Most folks use a hair dryer and dental floss. The dryer warms the double-sided sticky tape they are held on with and the dental floss can be used to slide underneath and saw the sticky foam. Clean up the residue with some 3M General Purpose Adhesive Cleaner. Be sure and mark where the current ones end first as it will make aligning the new ones easier.
