I bought a 2002 Carrera with the Xenon light option a year ago, for some reason the driver side low beam light is aimed very high. I have tried adjusting it using an allen wrench in the fender access hole, its now aimed just below the passenger side, just the way I want it. The problem now is that when I turn on the high beams the drivers side high beam is aimed at the ground. Are the low and high beams adjusted seperately? If so how is the high beam adjusted?
Mark
Edited by ffr2370
Hi
The low beam and high beam are not adjustable separately, there most by a problem inside the unit.
