I'm under the car stripping exhaust parts off to put headers on and notice a couple of things.
1) Car shows evidence of, what I would describe as, a very minor RMS leak - normal right?
2) See evidence of a very slight oil leak on the left side (drivers side) of engine case somewhere just above the header. Any ideas what this might be ? Can't really see an origin point, and I don't see any evidence of oil anywhere forward of this surface.
Cam cover maybe?
Andy
Edited by Andy_M
Might just be the overflow line on the PS reservoir.
Todd
Maybe I just corner harder to the right than I do to the left... :P
Todd
I have the same issue. My suggestion is to use some spray degreaser to clean the cam cover thoroughly and then drive the car until you see the leak's source.
John V
Todd
John V
Yea, I kind of thought along the same lines. The engine could use a little spiffing up anyway.
Todd
John V
Thought I would post an update. On further examination the leak seemed to be coming from the spark plug tubes. I replaced all of them and the o-rings and cleaned up the case, and it has been clean for several days with no sign of leaking. Very easy repair.
