Has anyone had both these two fault codes show up (I have an 00 base Boxster) after the CEL light came on? The fault codes are: P1128 (oxygen sensing adaptation area 2--cylinders 1 and 3--rich threshold) and P1130 (oxygen sensing adaptation area 2--cylinders 4-5--rich threshold). I have been told the problem is NOT with the two oxygen sensors but more likely a vacuum leak or bad oil separater, or even a bad mass airflow sensor. I'd really welcome feedback from anyone familiar with these fault codes before taking the car to a mechanic for expensive repairs.
Have you done a search here?
These same faults have been discussed many times here before.
Just search for p1128 and p1130.
Sorry, I'm a newbie here. I'll give it a try. Thanks for pointing this out.
hope i don't get blasted for replying but I just had these codes and mine was related due to a cracked seal in the oil filler cap...
So check your oil cap and the cap for the petrol first.
Edited by ChrisZang
  • 2 months later...
do we have an update?
First off, If your going to take it to get fixed, make sure he is a technician not just a parts changer, things can get expensive if its not diagnosed properly.
The Tech should first analyze the dme data and look for the tell tale signs of rich or lean condition, for lean condition I would then procede to look for vacuum leak, oil filler cap as Chris said, and If you dont have a smoke machine, use propane around the intake, oil separator ect. and look at the o2 signals for rich
reading, high voltage close to .800 1.0 volts. If no leak then most likely it is your Maf. By the way to test an O2 sensor to see if it is Biased Lean all you have to do is create a rich and lean condition and see voltage transitions, usaully with O-scope, transition time should be less than 200 milliseconds. if no transition then you have a dead o2 sensor. The tech should do a hard reset after erasing codes to reset the adaptation values back to 0.00
vizcarra44
  • 2 months later...
vizcarra44
are there any updates?
I have the same problems and no idea what to do anymore.
I already replaced the MAF, oil separator incl. J-Tube, Air- Check valve, but my Boxster is still stuttering and black smoke is coming out of the exhaust at higher rpms and at idle speed.
Here are my fault codes:
27 OXS sensing range 1, Cyl 1-3, P1123 or P1124
34 OXS sensing range 2, Cyl 4-6, P1129 or P1130
10 OXS Sensor before cat cyl 1-3, P0130, 0134, 0131, 0132 *
18 OXS Sensor before cat cyl 4-6, P0150, 0154, 0151, 0152 *
26 OXS sensing range 2, cyl 1-3. *
55 Misfire Cyl 6 emission related, P1318
53 Misfire Cyl 4 emission related, P1316 *
54 Misfire Cyl 5 emission related, P1317 *
62 Misfire Cyl 5 emission related, P1319 *
vizcarra44
You really have spent some serious money trying to repair this car. I suggest you find yourself someone who truley understands how the engine management system works and is a Diagnostic tech/troubleshooter. It is always better to test than guessing.
I replaced the two pre-cat oxygen sensors. The car runs perfect now- no gas smell, engine stuttering or black smoke anymore. After 40 miles the engine check light came back on (P0130), I assume it is due to the dirt and carb which is still in the engine. I added some Techron (Chevron) engine cleaner to the fuel and fired the engine with high rpms on the highway to get it hot and clean- seems to work! So far (140miles) the light didn't came back on.
