I am trying to rid the musty smell in my cabin.
I have the cabin air filter out.
In looking underneath, I can't seem to find any drain tubes for the A/C? All I can find is plastic undertray?
Any pics? or do I have to remove something?
There are a couple of drain tubes near the battery. All
of my are clear except one. I intend to run a small wire down it
some day. I would check these tubes.
Paul
You should be able to buy some deodorizer from an auto parts store that will work well. Remove the particle filter and spray some of the deodorizer into the evaporator box with the AC running. This will distribute it through out the vents and will clear up the musty smell.
Last night I ran a hard wire down one of the tubes betwwe the battery and the front fire wall.
Clean out the dust and leaves that were in it. I like the deodorizer idea and plan to
try this on another car I have that has been sitting around alot.
Paul
