4 stalk OBC connector
My orginal car doesn't have OBC function.
I purchased the 4 stalks control unit and I also purchase a cluster that came with OBC function (when I start my car, the cluster will display outsode temperture and do a serive check on the car.)
Here is my question:
at the bottom of the 4 stalks control unit, there are two connection, one is for curse control and the other is the OBC.
I can't find any connector from my dash board are that connect to the OBC connector from the 4 stalks unit.
Can anyone give me some hint what can I do to make it works
thanks
The car is not prewired for the OBC and that is why you cannot find a connector.
You will need to buy the connector, 5 VW wires, and make a wiring harness. 4 wires go to a connector for the instrument cluster and the 5th wires goes to ground.
