I've got an 03 996 C4Cab and the passenger window has a mind of its own. When you open the passenger window, rather than dropping a fraction of an inch, the window goes down 90%. Happened once before and i brought it to my local dealer for that and some other "minor" work (adjust hardtop etc) and they kept car for a month (a whole other story). Window was working fine for a while, now the demon is back. Dealer had said lamely that they thought it was due to the hardtop being out of whack. But the problem started before i put on hardtop, and now problem is back after a dealer adjustment to the roof.
Any ideas??
A
Window regulator might need adjustment and/or replacement. I'm assuming that you meant to say when you open the passneger door, and NOT the window.?
