Hi all
Repalced the MAF and it got rid of numerous problems as per previous posts, now the only issue is it needs some throttle to start and idle.
It takes about a minute to idle ok and drives great, although I would say the idle is a little rough but OK
Any ideas
Bruce
Hi all
Any ideas
Bruce
Clean or replace the idle spped control valve
Glyn
Yep, did that one (and had to drive the porsche centre and get the code, damm sticky notes rub off and blow away)
thanks
Bruce
have you reset the DME/ECU by disconnecting the negative battery cable for a minute, then reconnecting it?
(have radio code handy if your radio needs one.)
OK I'll look into that one, whats there to clean?
Bruce
Hi all
Any ideas
Bruce
Glyn
Do a search, there is info on the board here that I used when I did mine. Relatively easy to access but watch the gasket between the ICV and the facing -- I managed to break mine. Suggest you order another before you do the jb.
Bruce
Hi all
Any ideas
Bruce
Glyn
Inside the idle speed control valve there is a curved flap that opens and closes like a door, this gets gummed up.
It should move easily, clean it all out with carb cleaner, electrical cleaner and WD40 (yes i use all three)
get a tiny bit of grease and put it on the gasket (this will prevent air leaks)
Glyn
done as suggested, what a great maintenance idea, have some pics will post, thanks all especially Chris and Glyn
Bruce
Great improvement although it was 100f here today and although the car had sat for 24 hours and was technically cold the air was not but it started and run very nice and has run all day at lights etc beautifully. It will be ineteresting tommorow morning when hopefully its colder again.
Have documented in PDF with photos any suggestions where I can upload (file is a few meg)
Once again
Bruce
So I take it that cleaning the ICV cured the problem?
Once again
Bruce
Send it to Loren and he'll post it for you.
