I replaced the combination switch on my 02 996 about 3,000 miles ago.  I realize this is a common replacement item, but 3,000 miles is not what I would consider a reasonable timeframe to replace it again.  Is this consistent with other's experience?  If the life expectancy is that short I am hesitant to bother fixing it again.   The first time it was replaced, it was done at a reputable independent shop.
I was warned to never hold/force the stalk in the on position to keep the signal blinking during a complex turning maneuver, like in a traffic circle.
I have tried to be very careful with signal use since I replaced mine a one year ago for almost $400 for the part.
The left signal is already intermittently failing to self cancel after completing a turn.
Since the existing signal sound does not rise above background noise in these cars that leaves me phantom signaling as I proceed down the road.
Need to retrain to manually cancel the signal now.
This vehicle only has 50k miles.
I run vehicles 150k to 200k before disposing and have never changed a turn signal stalk in my life.
This part totally sucks.
Edited by Kevin Bryck
add
Agreed!  I am hoping something went wrong during the install.  I will do the next one myself.  The part may be poorly designed, but it really can’t be this bad I hope.
The turn signal not resetting as well in my 2002 Carrera cabrio.
I think it is nit that annoying so I do turn the signal iff myself after a turn. It us not that bad. Just a habit as my 1988 Mercedes 500SL has that problem as well on left turns!
I feel not worth the cost if repair.
Other option is not to take turns and just go straight [emoji1787][emoji1787][emoji1787][emoji1787]
K
Sent from my iPhone using Tapatalk
Kevin,
I'd like to take you up on your offer if your old Steering Control Switch Assembly is still available.  I've been thinking of gettign a 3d printer, and sinc emy newly acquire 2002 C4S is experiencing the same problem, I'd like to see if I could fashion a fix.
