guys help here
i am getting this really light noise from under the car when the car is in motion .. its a light creaking noise... sounds like a door without proper lubrication ..but much lighter and higher in pitch .. not as heavy ....
what can this be.. control or or the sway bar end link?
i did get my end link change for the rear at 36K km ... but i havent change the front... i have a 2001 C4 cab....
but i did notice the rear end link is much tigher .and if u try to twist it the room it gives is alot less then the front.. is this normal.. is the front suppose to be more loose and gives more room for twist and turn?
does the end link make this noise at all?.. or is it something else?
any thought and info would be awsome..
thanks
