My Litronic retrofit kit showed up today (man is that a big box or what?) and when I pulled the gleaming beauties out of their respective boxes, I noticed that the internal light assembly appears to be grossly misaligned. Do they just need to be adjusted? Or is something really wrong? They don't rattle, yet when you take the back off, the connector on the back of the top bulb is touching the black box (real technical, huh?)
Any help, advice, etc. is greatly appreciated.
I've been doing some reading from several different sources and from what I've read, a common problem is that the ball and socket gimbal can come loose in shipping, which appears to be what has happened with mine. I'm going to have to partially disassemble both lights to reset them. It's just so tight in there and difficult to see what you're doing. Nothing is ever easy anymore.....
But soon you'll have Litronics up front! :clapping:
Edited by Westcoaster
