I have a 99 C2 Cab with Traction control. I believe this car come with LSD (limited slip differencial) What exactly this LSD is supose to do? I believe it puts the power at the tire that has more grip when getting out of a turn, am I right?
Will this LSD work with the traction control off or on? Or will it work either way?
Thanks in advance.
LSD transfers power to both wheels instead of just the one by means of a cone type clutch system - typically. So you have better traciton and no peg leg burnouts!
Yes. LSD is always on.
Traction Control can be switched off. TC was a forerunner to todays PSM.
