I have a '99 996 cab with removable hard top. There are two round plastic covers that cover the latching mechanism on the rear shelf (below the rear window one on the right and one on the left). When I removed the hardtop, I put these covers back in the holes over the locking mechanism. I must not have gotten one of them seated right and it popped out. Any help with a part number for these pieces? Mine are grey in color. Also, when I purchased the car it was missing the plastic cover that goes over the latch in the center of the car where the top latches to the windshield. If I'm ordering parts, may as well get them all. Again a part number would be greatly appreciated. Thanks in advance.
Will
OK, here are some numbers for you. The caps are 996.555.457.00, C50 in graphite grey, B50 in space grey. My PET shows only graphite grey for MY99, but you should check to make sure of your color.
The front cover is 996.563.551.00, 01C in black. Please check this number with your parts source as it is hard to tell if this is the right cover on the PET diagram.
Good Luck
Good Luck
Hey, thanks for the info. I really appreciate all of the help available on this board.
Will
