My 2001 986 S runs very well with the exception of an idling problem.
When the car is left to idle at operating temperature, after some 10-15 seconds the idling becomes uneven. However, the engine never tends to die down. When the the A/C is on idling is more stable.
I changed the MAF sometime ago and the situation has improved but it is not perfect. The car has an ECU upgrade plus headers and muffler from Techart but the problem started some time after I had tose fitted.
Any ideas and suggestions about the possible causes and areas I should look?
Another point is the rattling noise from the drivetrain when idling warm which is eliminated when the clutch is depressed. I've read a post about what causes it but I don't remember. Can someone remind me please. I think this doesn't indicate a fault (it is just a nuisance) or am I wrong?
