Hey everyone, great site. I have read in Excellence that 996's had RMS problems, which if I remember correctly were described as rear main seals or something like that. I had a 996 (bought with 5 miles or so on it and like others who bought new did not burn any oil in 4 years and 15,000 miles) -- no RMS problems -- nothing wrong with the car at all. The most reliable car I have ever owned, though 15,000 miles is not very many miles.
My question is: have 997's been having these RMS problems that Bruce Anderson talks about in Excellence? Am thinking about a used 997 or used 996.
Many thanks in advance and your indulgences if I have not described this adequately, more so if this is a well discussed problem here. I am so new I do not yet know my way around here just yet.
My manual 6-speed Porsche experience is w two 96 993's, a C4 and C4S. I found it took of in traffic better in 2nd than 1st and around town I used 3rd as "drive" I NEVER used 6th, the motor doesn't like it
Some people like to put lower, European gears into the US boxes but the Euro 1st is or was a stump puller
All questions are good questions - how else do we learn, I never stop.
Drive safely, If you do PCA driver's ed with an instructor you will benefit. You should reach a point with eyes on the road that you shift by sound and feel, at one with the machine, and cruise around in the sweet spot between 3-4k revs....
David
www.fractional-supercars.com
93 964 C2 Cab
Looking for low mileage 964/993 Turbo with pedigree an service history
The RMS issue has probably been discussed ad nauseum. However, it seems to be rare in any 996 from 2003 onward. Since most pre-2003 cars either never had the problem or have been repaired, it is fairly likely that you wouldn't see an RMS problem in a pre-2003 you might buy. Thus, purchasing a used vehicle is more a matter of assessing its condition & prior treatment (like any other car).
This has been covered here.....a lot. Anyways, the new seal has proved to be pretty much stone cold reliable. All 997s with the exceptions of the early 05s have the new seal. That being said, I would buy a 997 regardless. Even if it has the old style seal you'll be under warranty for close to 3 more years so if it does leak, make an appointment at the dealer and pick you car up the next day with the new seal.
