hi,
i've always put in chevron gas and just the other day i was forced to put in arco (i was running low), so i only put 3 gallons in...hoping this is only a coincidence.
i noticed the following day it hesitated starting and now today it won't start at all. anyone have any ideas? when i turn it over, the windows go madly up/down (not all the way, but like when you normally open/close door).
are there any checks i can perform to rule anything out?
thanks in advance
Edited by rdragon
if the battery is dead, would the battery warning light come on? are there cases where that light does not come on even though battery is dead?
Sounds like you have a bad/dead battery. There is no dead battery warning light.
If you have a charger charge the battery then go to an auto parts place and have the battery tested.
