I just changed the brake pads on my '05 V6 Cayenne, but the brake pad warning is still on in the display. I accidently broke some of the front sensors, the back ones are fine, so I don't know if this might be the problem. I also have an '05 Boxter which I change the pads and did not re-install the sensors and works fine, no warning. Do I need to reset the warning or do I have to get new sensors? Thanks.
How hard was it to change out your brakes?
Really easy, as with any other Porsche. Just remove the pin, remove the old pads, insert new pads,reinsert pin, that's it. Took me around 30 min for all four.
