the problem is when i lift the door handle to open the door the window goes down (like it should) but the door won't open, there is no click, i then have to open my paasenger door and i can then open it from the inside! weird. Anybody out there with an idea to solve my problem?
The handle on the outside of the car is connected to the door lock mechanism via a short rod which is anchored to the lock by a sliding ring, this may have broken or come loose.
Get the door panel off and have a feel above the lock, put the rod back into the sleeve and slide the ring up over it.
Sounds tricky, but it is simply and can be done just by feel
Glyn
Glyn
thanks glyn.
