I once looked into fitting someones surplus Turbo spoiler to my C4S coupe. Apparenty, it will fit a 996 C4S Cab but not a coupe as the deck lid is a different length on the Coupe.
rear lid is same length, the support panel below rear window is slimmer on a c4s than it is on a turbo and gt2, this panel can be changed so a turbo or gt2 lid can be fitted, also you will need to alter the airbox as the rams from the spoiler obstruct this, a corner will need to be trimmed off then rebonded to give the correct clearance, ramus porscha in west bromwich uk specialise in this conversion.
I purchased a rear spoiler by Cargraphic which might fit your bill... it is turbo-look and fits the C4S. The wing blade is fixed in the up position. As far as I know there is no cost-effective way to make it electronically go up and down (in case you were wondering). It also allows you to incorporate the C4S reflector. Attached are a few pictures of the rear spoiler. Sorry I don't have any on the car, as it is yet to be installed.
