driving along this evening in heavy rain and my abs light came on. i have swithced the car off and back on again several times, and it still comes on but not instanly. the pump does work when the light doesn't come on when i have applied the brakes hard enough to try out the abs.
any common faults?
any common faults?
chec kbrake fluid first. May be low as you may be approaching the need for a brake job as well. When was last brake service??
demosan
I've heard of others having a similar problem with moisture re:rain and ABS lights. seems to be a common ailment. Might suggest blowing the connectors out with air and see if the trouble goes away. If so maybe a bit of silicone grease application to the connectors might be benifical in keeping some of the moisture out.
