Hi guys. I'm in the middle of a brake pad swap and I ran into what may be a little problem. My rotors have a pretty good lip, and when I tried to fit the new pads, the outer lip prevents the pad from sitting flush against the rotor. It is very close, but I can't force it in with just hand pressure, and don't want to step on the brake without first checking with the experts.
So, should I try to bed in the brakes anyway, even though the pad is sitting against the lip instead of sitting against the rotor? Should I just spring for new rotors now as opposed to a few more months when I planned to do so?
Also, should I be concerned that the inside pad was much less worn than the outer pad? Thanks, Scott.
Hi, no, no, no, please do not put those new pads to that lip.
I would recommend having the rotors surfaced or replaced if necessary if the lip hits the surface of the pad and it does not damage the pad/ chip of a chunk it will definately lower it's effective braking surface and it will lead to premature pad failure(besides a mere 10% more braking surface makes a big difference, reduced temp, less fade, all by working more effectively). I'm not a brake Guru but from my experience on and off the track, it is normal for one pad to wear at a greater rate than the other. If you look at where the pad wear sensor is mounted it will correspond with the pad that is worn greater. Hope this helps, Jim
Hi
Fit new rotors, they are probable out of limit. When you replace the rotors fit ALWAYS new pads.
Regards
They are mintex pads (red box I think, the ones with the large weights at the corners). Actually, I don't need to post a photo...the lip is freaking huge...I was just trying to cheap out. worn pads are back on and I'll pick up some rotors on monday.
Scott,
the way you describe the lip reads to me like you need new rotors. They are easy to replace too. I replaced mine at around 55K miles, they are on the verge of being out of spec. And the lip was not that big. Mintex redbox should drop in like a replacement exactly.
for replacing
http://www.renntech.org/forums/index.php?s...;hl=rotor++spec
for thickness spec
http://www.renntech.org/forums/index.php?s...;hl=rotor++wear
