Going to pick up the BG fluids right now. I'll post if it does the trick allthough the results would be unfair as it is supposed to be 80 here for the next couple of days. I won't be able to do the test for about 2 weeks I have to go to Indy for business.
Be sure you also get the friction modifier in the little tube. Cannot for the life of me remember what is was specifically called but I believe it was for LSD apps. Let us know what you get with it.
Well, The rep brought a 2+1 kit including 2 bottles of the Syncroshift II gear oil, and one squeeze tube of LSII Limited slip additive. He is going to bring another bottle later as he only had the one kit with him.
Allright You do need 3 bottles and the additive. I had the dealer put the fluid in for me when they put my new A/C compressor in. I have noticed a little improvement in the ease of shift but it did not hit the big problem with the 2nd gear. I am all well believing it has something to do with a odd grommet protruding down from the doghouse directly over the linkage. I will try to check it out just don't know when I'm heading out to Cali for a while and possibly overseas again there after if I do not have a chance to get to it I'll just have it sent to Power Haus. Many thanks for the recommendation. Jim
Jim,
Give it a few miles before taking any expensive action. IIRC, it just got better as I drove it more to the point that the problem resolved itself totally. Since my car is a daily driver, you might want to schedule a nice weekend jaunt to the Ozarks or down to Grand Lake and enjoy the sunshine while you work it out.
