Thank you but I think this part # is if I owned an 04 and wanted to upgrade my system to a model year 05. I own an 05 so I think I have this update by default
Though there is no alternative map that will run on the porsche PCM2.1 than porsche's own brand , the maps are supplied and manufactured by Navteq. Typically navteq update the mapping data twice a year (in europe) so there is usually a new map DVD available. This will have updated maps but probably no more levels of POI. They are expensive too, in europe the MAP dvd updates cost about 500 euros (700 USD). The update DVD is usually supplied with a firmware update disk that allows the earlier 2004 model PCM2.1's to run the later map disk and may enhance the features and detail on later PCM 2.1 units. normally the supplying dealer perform the updateof firmware free , when you buy the map update.
