Right after much searching I am hoping for a little help, I have seen a brake kit which I wish to replicate using my own parts from various sources, can anyone tell me what Prosche these calipers are from as the people who supply the kit told me it was from a specific car and other similar ones could not be used, i though most of the 6 pot calipers would have been the same in size etc..
the pics below are of the parts. thanks ali
http://www.powerstation.org.uk/porsche_brakes.asp
sorry can't seem to get the pics up but if you scroll down and click on the pics you should be able to see the caliper..thanks again
Someone can correct me if I'm wrong, but I think the GT3 fronts are the same caliper as the PCCBs calipers found on cars with the ceramic option. If so, then red paint for GT3 6 pots and yellow paint for PCCB 6 pots would be the only difference?
Edited by mxdave74
They certainly look like the red Porsche/Brembo calipers that come on the 996 GT3. It would require the part number to be certain. FWIW, their kit is advertising 355mm Dia X ?mm thick AP rotors. The 996 GT3 front rotors are 350mm OD.
  • 3 months later...
