hi,
i am looking for different modifications on boxster muffler
does anyone have a image of cut and modified exhaust ? i have a 2.5
i was at first gonna do the mod where the 2 pipes are added to the side, but no shop around my are can handle smaller tubes for soem reason
and lastly, i was also thining fo making a custom one with magnaflow mufflers and twin outlet tip, so if anyone has any experience with either or i would appreciate the help
thx in advance
Djomlas wrote:
> have a image [...]
> but no shop around my are can handle smaller tubes [...]
> i was also thining fo making a custom one with [...]
Is this English..?
-- peer
hi,
thx in advance
Try a honda/acura performance shop in your area. I build turbo cars mostly Honda's and we use smaller diameter pipe for wastegate and other items which would be suitable for doing the OEM muffler bypass mod. They could do it for you no problem, just bring in a picture to the shop. Make sure you find one that does turbo and custom work and welds up custom exhaust systems. That way you will know they are competent with welding and fabrication. We have guys come in with snowmobiles and trucks and stuff and we do odd jobs for them all the time cause we are known for weird fabrication and can do whatever people are looking for.
You can buy a muffler from ebay pretty cheap. Compare say $200-300 for a custom job done to your vs. some of these options:
Dansk Style new: http://cgi.ebay.com/ebaymotors/97-04-PORSC...sspagenameZWDVW
Dansk Real used: http://cgi.ebay.com/ebaymotors/Dansk-Porsc...sspagenameZWDVW
Custom Twin Muffler: http://cgi.ebay.com/ebaymotors/Porsche-Box...083001061QQrdZ1
OEM PSE: http://cgi.ebay.com/ebaymotors/Porsche-Box...095172236QQrdZ1
Should be able to find something there you like. Search for "Boxster Exhaust" to see more.
Edited by 986Jim
thx in advance
Like this?
Those are two Magnaflow mufflers with two 3" tips. DON'T DO IT, unless you are already deaf or really like feeling like your head is about to explode. There is way too much science in effectively designing exhausts for these cars that don't resonate that I recommend you not waste your money.
  • 9 months later...
