I was wondering if anybody can help me.
I search forum already and could not find the answer.
I want to buy a wheels with tires. I found used set that I really like. The only problem is those rims are from 996 narrow body and they are huge.
Wheels size: Front 18x9 and Rear 18x11
Offset: Front 40 and Rear 52
Tires: Front 255/35 and Rear 295/30
I really like those rims. I know that tires might be to big but I can always buy smaller. What about wheels?
So my question is: Will they fit? Do I have to use spacers? If they will not work is there anything I can do to make them work?
Thank you
P.S. My suspension is still stock.
I don't know how much the 1/2 inch bigger the one you like will do. For the most part a lot of the guys in the forum who elected 18" wheels have 18X10 rear and 18X8.5 front which seem to be the prepared size for all application. I on the other hand like the formula wheels and they only come in 19" have not made up my mind yet which way to go, but I need to make it soon spring is coming which means racing. Some of the tires size some posted in the racing forum are 225 30 and 225 35's. I like the wide look from the rear which I would think give the car a better handling. The Boxster rides like a "go cart" as it is for handling any upgrade I'm sure will make it even better.
Ben
11" is too wide on the rear. 9" is getting pretty big for the front, but I'm not sure about the offset since this is not a popular fitment. I would pass. There is no hope of fitting 295s on 11" rears unless you plan on doing some serious body work.
