i have this engine vibration at 3200 irrespective of being stationary or moving. it is not the balancing of the tyres or cv joints. it occures when holding the revs at that speed or wheen decelerating. the car is a 1999 2.5 manual.
Since it only happens while you are holding it at that particular rpm you might want to check on the ignition system. It sounds like it is mis-firing, like one cylinder not wanting to firing.
Ben
Hi
If it is a 2.5 l engine, check the engine mount on the front of the engine. The silent block is probably out of the center, if it is so , replace or repair.
