Here's a new, comprehensive review on the 2007 Porsche Carrera 4/4S Coupe, with detailed information on design, performance, safety and options. Available is also a video clip and photo gallery with the car.
"The width of the car shows the difference: The most striking, eye-catching highlight of the 911 Carrera 4 and 911 Carrera 4S are the wheel arches flared out on each side by 22 millimetres or 0.87”, accommodating 295/35 ZR 18 tyres on the 911 Carrera 4 and 305/30 ZR 19 tyres on the 4S. A feature shared by both models is their four-wheel drive conveying power to the road..."
You can read the whole article here: http://www.topspeed.com/cars/porsche/porsc...pe-ar27316.html
That's one sweet *** that C4S has. Plus the C4S has 355HP instead of the 320HP the 996 C4S has. They got rid of the turbo look and reflector strip on the back, an option I like. I was wondering if the brake pads will be have to be replaced more often because of the PASM pre loaded brake system function that pre loads the brake hydraulic pressure causing the pads to ride the rotors when the gas peddle is released suddenly? Porsche is still pushing their PCCB on us as an option.
