Think it is about 24 hours iirc. Have patience!
I got "WAIT" 48 hours ago.
Dealer gave me correct code today (I hope), but it's still on WAIT.
That's 48 hours, during which the car was running for about 6-8.
Does anyone know whether it's time or time-during-which-the-radio-is-on ?
CP
The radio manual says that the waiting time is when the ignition and radio are switched on.
After 3 wrong attempts with a code you get wait, and have to wait for 1 hour before trying a code again.
But I remember from the old Becker board that if you enter the wrong code way too many times, then the radio has to be on continuously for 24 hours before you can try a code again. This is a problem as most owners will not want to leave the ignition on for 24 hourse. Horst of the Becker board said that they power up the radio on a test bench.
At least that is what I remember from the old Becker board.
Thanks, that was very helpful.
Looks like more time in the driver's seat for me. (Darn, that's a severe punishment: I have to drive my Porsche.)
  • 4 weeks later...
I replaced my battery today and dont have the code for the radio of course so I could use the code. :rolleyes:
01 C4
4462
serial #Y5052199
01 C4
4462
serial #Y5052199
Try 8378
or
8380
01 C4
4462
serial #Y5052199
Try 8378
or
8380
:renntech:
Thanks Loren the second code worked
Thanks again
hi ! same problem with me,i need a radio code
becker 1
type: 4462
48/98
ser: x5018077
thanks
vince.
Edited by sir16
  • 4 weeks later...
I changed my battery and found out that my radio was replaced sometime before I owned my 99 cab. So, I have the original radio code card but it does me no good.
I just pulled the radio. Can anyone help me?
It's a CR220
Mod# BE 4362
S/N: 15031442
Thanks in advance...
Dan
Dan, I have the same radio in my '01 Boxster S:
It's a CR220
Mod# BE 4362
What code worked for you?
Thanks, PBXJedi
The code is based on the radio serial number. The last 4 digits of the radio serial number are put into the radio decoder, and then the decoder guesses at the code. You code is not going to be the same as the code for another radio.
Swapping the Battery Tray and I am another for the list.
Becker Radio 220
Serial # 15087065
it also had # 4462 come up when I was turning the knob.
I had one of those chargers plugged into the lighter socket but it did not work...
Care to share the trick? I have looked at a few serial #'s and cannot see the pattern.
4462 should be the model number for a Becker CDR-220, not the code.
With a radio serial number ending in 7065 the decoder says ... 5293 is the unlock code.
Why are you swapping the battery tray?
Would someone help me out with the code for 4462 / Y5051903. Thanks.
----Nevermind. Found a calculator on the 'net. Code was calculated code +2.
Edited by khockstein
My battery tray is rusted from a previous battery explosion from the PO. Not sure if it would ever rust through, but the new one sure does look nicer!
I will go try the code.
Mine isn't reset yet, although being disconnected on friday this week to complete an install.
Becker-220
Serial #15001542
Type 4362
24/99 (what does this mean)
Gal 00 (whatever that means also??)
Any help would be appreciated. After installing my new aux cable, I would rather not have the deck not work at all :)
  • 6 months later...
Another person seeking assistance. I have the CR-220, type is 4462, serial number is 15005382. Any assistance would be GREATLY appreciated as I haven't had a working stereo for two months!
Thanks.
This topic is now closed to further replies.
