Now that I have this info, how do I troubleshoot further?
Thanks.
Year: 1999
Make: Porsche
Model: 996
Engine: 3.4
VIN:
License:
Mileage:
Stored:
P1123 O2S Sensing Range 1 Cyl. 1-3
Pending:
P1125 Oxygen Sensor Adaptation, Upper Load Range, Bank 1, Above Limit
MIL ON
Misfire Monitoring Complete
Fuel System Monitoring Complete
Comprehensive Component Monitoring Complete
Catalyst Monitoring Not Complete
Heated Catalyst Monitoring Not Supported
Evaporative System Monitoring Complete
Secondary Air System Monitoring Complete
A/C System Refrigerant Monitoring Not Supported
Oxygen Sensor Monitoring Complete
Oxygen Sensor Heater Monitoring Complete
EGR System Monitor Not Supported
DTC For Which Freeze Frame Was Stored P1123
Fuel System 1 Status Closed Loop
Fuel System 2 Status Closed Loop
Calculated LOAD Value 1.96 %
Engine Coolant Temp 197.6 °F
Short Term Fuel Trim-Bank 1 0.78 %
Long Term Fuel Trim-Bank 1 3.91 %
Short Term Fuel Trim-Bank 2 -0.78 %
Long Term Fuel Trim-Bank 2 2.34 %
Engine RPM 689.50 rpm
Vehicle Speed Sensor 0.0 mph
Automatic Transmission Problems:
Check Engine Light:
Light Always On
Driving Conditions When Problem Occurs:
2-10 Miles
Driving Habits:
Mostly City Driving
Engine Quits Or Stalls:
No Symptoms
Engine Temperature When Problem Noticed:
Warm
Problem First Noticed:
Started Last Week
Gasoline Used:
91 Octane
More Than 91 Octane
Idling Conditions:
No Symptoms
Peculiar Smells:
Problem Occurs:
Morning
Problems Starting Vehicle:
No Symptoms
Running Conditions:
No Symptoms
Strange Noises:
Weather Conditions When Problem Occurs:
32-55 F (0-13 C)
Transmission Type:
Describe The Problem:
I had P1123 and P1125 for a long time on my car (UK Spec, so no CEL). I tried the remedies in the manual: fuel pressure, EVAP canister purge valve, etc, but what fixed it was a new MAF.
For a 1999, you may have over 60K miles? You may be due for O2 sensors and MAF. I had the same exact codes on the same year, 62k miles. MAF and O2 sensors cleared it
The problem came back and now I see the pattern. I hope this information can help someone further troubleshoot the issue.
Based on FF, I can tell you 1123 gets trigged when the engine is in idle. Temp of Cool = 195.
Does it help at all? Should I just go ahead and replace the MAF? Yes I did clean it.
3/20
Engine Coolant Temp 194.0 °F
Short Term Fuel Trim-Bank 1 -3.13 %
Long Term Fuel Trim-Bank 1 8.59 %
Long Term Fuel Trim-Bank 2 6.25 %
Engine RPM 703.50 rpm
4/1
4/5
Calculated LOAD Value 1.57 %
Short Term Fuel Trim-Bank 1 -2.34 %
Long Term Fuel Trim-Bank 1 5.47 %
Short Term Fuel Trim-Bank 2 -2.34 %
Long Term Fuel Trim-Bank 2 3.91 %
Engine RPM 708.00 rpm
What does your MAF read at warm idle?
Unfortunately, my OBD reader (Innova 3110) does not give me that information..
Anyone in Redmond,WA to help me out ? :-)
