I just blew a rear tire. The other three have great treads, more than 50% life left in them and I hate to replace a set let alone all four. I understand the Contsportcontact N1 has been discontinued. Does anyone know where I can get a single tire of the same model. If I can't, can I replace just the rears and which tire should I use to closely match the front Conti N1's?
Thanks in Advance
Hank
I got my ContiSP2's from Treadepot. I was also searching high and low for them.
I had to replace only 2 rear Contis, or whole new set if I couldn't find the Contis.
I wouldn't recommend replacing only 1 tire, especially the other one on the same axle is 50% or more.
Even if it's fairly new, it could still give you tracking, or shimmer issues when you're driving.
